Depends on three things.
1. Rigidity of the WTC. How does it handle the pressure.ie is it compressed by the water pressure (very small factor)
2. How much does the temperature rise from the internal components engines, esc, etc.
3. most important factor. What is the displacement of the piston tank against the volume of the wtc.
Pressure1 x Volume1 = Pressure2 x Volume2
This means, when the volume decreases the pressure rises.
Half the volume, twice the pressure.
I'd say a couble of tenths of bar. Every meter the water pressure rises with a tenth of a bar. If you plan to dive to 1 meter an overpressure of one tenth of a bar should suffice. Added to that, the pressure in the hull rises by the piston of the piston tank compressing the air in the hull.
Internal pressure has 2 major advantages.
Leaks are easily spotted as bubbles come out.
Internal pressure makes it harder / impossible (when the internal pressure > external pressure) for water to get in.
PS, I intent to pressurize my sub till 0,2 bar as my depthregulator allows me to dive to 1,5 metres.
EJK
