Working Under Pressure - How Much?
  • ramius-ii
    • 393
    Hi All]http://www.subcommittee.com/forum/icon_question.gif[/img]
    Thanks, Ed
  • koeze
    • May 2003
    • 204
    Depends on three things.
    1. Rigidity
    1. Rigidity of the WTC. How does it handle the pressure.ie is it compressed by the water pressure (very small factor)
    2. How much does the temperature rise from the internal components engines, esc, etc.
    3. most important factor. What is the displacement of the piston tank against the volume of the wtc.
    Pressure1 x Volume1 = Pressure2 x Volume2
    This means, when the volume decreases the pressure rises.
    Half the volume, twice the pressure.
    EJK
    • ramius-ii
      • 393
      Hi EJK]
      [color=#000000]Hi EJK]
      • koeze
        • May 2003
        • 204
        Sorry Metric system.
        I'd say a
        I'd say a couble of tenths of bar. Every meter the water pressure rises with a tenth of a bar. If you plan to dive to 1 meter an overpressure of one tenth of a bar should suffice. Added to that, the pressure in the hull rises by the piston of the piston tank compressing the air in the hull.
        Internal pressure has 2 major advantages.
        Leaks are easily spotted as bubbles come out.
        Internal pressure makes it harder / impossible (when the internal pressure > external pressure) for water to get in.
        PS, I intent to pressurize my sub till 0,2 bar as my depthregulator allows me to dive to 1,5 metres.
        EJK
          Hi,
          The answer to your question
          Hi,
          The answer to your question is difficult to answer, because the pressure inside the WTC will vary from boat to boat.
          However, the lower the pressure on the back of the piston, the better, as this will result in less current being drawn by the piston tank motors.
          I would say between 6-12 PSI would be a good figure to aim for, 20-30 PSI will require a very well constructed WTC and powerful motors.
          • ramius-ii
            • 393
            Thanks so much guys. http://www.subcommittee.com/forum/icon_smile.gif
            I had often wondered what internal PSI to design for. This helps alot.
            Ed
