Review of the Pegasus NAUTILUS
  • modelnut
    • May 2003
    • 432
    I also want to light my kit.
    - Leelan
    • 1367
    Re: Review of the Pegasus NAUTILUS
    I'm currently in the middle of a build of one of these for a friend of mine out of NY. Beautiful little kit. I've added lights to the interior and exterior as well.
    Highly recommended!
    • modelnut
      • May 2003
      • 432
      OK. Here are the measurements.
      Main hull 29.3cm or 11.53in
      LOA 39.73cm or 15.6in
      144 scale gives the hull at 42.2m or 138.4ft. And LOA would be 57.2m or 187.7ft.
      This is far short of the 70m length given in the book. The model needs to be 48.6cm or 19.1in long.
      - Leelan
        • 1367
        Here are a few shots of my work-in-progress Pegasus buildup. I'm just working on a custom display stand with some more LED lights and it should be ready to go!
        • redboat219
          • Jan 2005
          • 523
          Any possibility of this model to be RCable?
          • modelnut
            • May 2003
            • 432
            The model is less than a foot long. I don't think there is much you can do with it other than use it as a pattern to make a bigger model.
            - Leelan
              • 2356
              Bob,
              Did you dry brush the hull with a silver? I like the effect. How did you do that?
                • 1367
                Tom,
                If my fading memory recalls correctly, I did a base coat of silver followed by a layer of rust solution (you see that on all my Nautilus builds), then another dry-brushed layer of silver to tone back the rust again.. I think there may also have been a wash of thinned black in there somewhere as well.
                I still have two of these on the shelf unbuilt. I really love them.
                  • 2356
                  Thank you! I can run with that.
