TK-17 Arkangelsk : a long road of patience
  • gabriel l
    • Apr 2012
    • 10
    Hello everyone !
    First of all, I will notice you that you can follow my building thread from the start here on TK-17's Captain log : http://www.wis-nha-tenebris.com/index.p ... ut=default
    And here for recent input ]http://www.scalesub.com/viewtopic.php?f=63&t=37[/url]
    I'm apologize about my bad english, Still a froggies after all, and I will try to keep you inform about my TK-17's project in futur, here and on Scalesub forum with english subtitle when it need the most.
    When I started this project, wooow 2007, I wish to achieved the most accurate models from Engels Kit inspire by Ramesh work on TK-20. This was a long road to gather informations, pictures materials, and a lot of headache to proceed proper modifications without compromise integrity of the hull. I wish to thank Wayne of course, Ramesh and some friends to support me during this years !
    Actually, I almost finish the hard part of this achievment. I still need to add a lot of details like tiny grid, doors on the hull and finishing to get a smooth surface for painting. Recently I've detected some leaks who need my attention, no big deal but time waste. I need also add some lead ballast to get proper waterline (upper waterline) and then she will put to see this summer if I have time to complete last structurals modifications. Final painting will be come later I think !
    I also barely finish the new vectorised plan for TK-17. And then I will work on TK-208 after her recent 941UM refit (bulava modification etc...). Recently I have new information about TK-17 and I'm still perplexe about what I've learn. I'm waiting pictures to confirm, and will discuss about this later.
    I have no plan yet for "batch two" TK-12, TK-13 and TK-202
    Here is some pictures extract from captain's log ]http://www.wis-nha-tenebris.com/ImagesRotators/TK-17/TK-17_-(38).jpg[/img]
  • wayne frey
    • 925
    Re: TK-17 Arkangelsk : a long road of patience
    Excellent!!!! Put it all here!! An excellent example of scale submarine modelling!
    The leading edge of the sail is silver? A camera?
      • 2349
      S'il vous plaît pardonnez mon post sur les plans, il semble que vous les avez ici. Merci beaucoup!
      Thank you for this excellent post and I will assume the drawings above are the more accurate ones which answers my question from a different post.
      • wayne frey
        • 925
        I will chime in here.
        His revised plans are extremely accurate. They are accurate enough, they are specific to TK17.
        It would be interesting to list the modifications and differences between your TK17 , and the origional Engel hull. I remember many of them, and can see them. But to the readers here, the troubles you went through would be appreciated when you show them.
        Footnote, my friend. My X tail Akula came back to me yesterday in the mail.
        • gabriel l
          • Apr 2012
          • 10
          Salmon> send me an MP with your mail adress I will see what I can do for you
          Ok Wayne, I will do a "resumé" for you about differences and modifications
          1- Conning tower :
          2- Castor Tail
          This modification is 100% accurate for TK-208 and TK-20, I've dry photo of this part. Recently I've doubt for TK-17 so perhaps I do wrong when I modify this part... I'm waiting to find TK-17 on dry dock to confirm :
          3- Port and starbord towed sonar array
          4- Rudders
          5- Reactor cooling inlets
          6- Housing Tactical Communication buoys
          7- Escape pod location and details
          8- A lot of other details
          9- Other details
          10 - Technics
          Engel's modify and create "tech Carrier" for WTC after I've done modification on bow plane servo, so a part of this work is no need now. I'm still have to do some details and etching on missile deck
          Safety rail on TK-17 are different that I've done but modify them should compromise hull integrity.
          So, basically all modification I've done on Engel's hull
          • Wheelerdealer
            • 315
            Hi Gabriel, good to see you on here and glad to see she is finally nearing completion. I took a break from model subs to do some other stuff (I remember you did the same a couple of year ago!), but seeing your progress has now got me thinking about starting on a new Engel Typhoon again
            • gabriel l
              • Apr 2012
              • 10
              He he this is a Typhoon disease
              Well I grab more and more Intel about TK-208 And I'm sure we have a pleasant discussion about ^^
              • gabriel l
                • Apr 2012
                • 10
                Today, it start awfully wrong !
                I have this picture of Typhoon since several months and I've a doubt about her identity. Now I've confirmation it TK-17 !
                And then my nightmare begin !
                I don't know yet when this photo was taken (perhaps 1991) but I can tell on things, this [censored] has keel on her sides. Meaning it has a "castor tail" short as TK-12 and the unmodified's Engel hull !
                And there, I have a case of conscience because I haven't the courage to redo this part ! And of course I need to update my plan until I have confirmation of 2002 Refit remove/modify that part >_<
                Furthermore, I continue to work on the shuttering of the ballast. I will soon be able to put resin and lead ball
                I've made with plasticard Evergreen the maintenance box of towed sonar array. One of them on port side has just be placed !
                Now I'm going to sleep for a while... too stressfull this day was !
                • gabriel l
                  • Apr 2012
                  • 10
                  This morning I decided to put the last small grids who'll be take place on the ground of starboard walkway. Otherwise, I've placed the starboard maintenance box of alr
                  A conning tower vue with the Arkhangelsk patch on the sail
                  • jeffrey j
                    • Apr 2004
                    • 398
                    I vote to move this guy into first place. Wow, just ran across this build, very nice, the detail is over the top.... nice , nice work, two thumbs up!! thanks for posting. Jeff Jones
                    • gabriel l
                      • Apr 2012
                      • 10
                      Building is in pause actually, but I will manage to continue soon
                      • hardrock
                        • Apr 2015
                        • 18
                        Hi Gabriel. Have you continued? Can you tell me where you got the brass grills from?
