WTC How far Underwater?
  • ramius-ii
    • 393
    Hi all,
    Now I have a question for those that have built and operate the Engel Typhoon sub. The sub has a water tight compartment that houses the electronics. When the sub is in the water and trimmed, how far underwater is the top surface of the WTC?
    Thanks, Ed
    Re: WTC How far Underwater?
    In mine, the designed waterline is basically flush with the top of the dry compartment. In actual operation, however, I think it will sit about an inch under, as I can't get enough buoyancy out of the twin tanks to allow for full emerged waterline.
    • ramius-ii
      • 393
      Thanks Bob!
      I am considering where to mount a sensor to know when the sub is at the surface vs when it has started to dive. I just was not sure if this could be "flush mounted" or if it would have to be raised up.
      Best, Ed
      • Wheelerdealer
        • 315
        Mines flush with top of the lid as well. However I can get mine to sit at the designed waterline with a lot of 'volume reduction' of the top hull.
