sub glue ? - stickin together
  • guardian
    • 18
    Hi all what are some really good glues for putting a fiberglass sub together ? and for attaching resin parts ? I heard from a friend that T-88 was the Bentley of glues for sub, Tor F ? also what are the pro's and con's of each glue ?
    Thanks,
    Mike
  • adriaticsea
    • Jun 2003
    • 139
    Hi Guardian,
    I'm building a 1/96
    Hi Guardian,
    I'm building a 1/96 Thor Permit, and, following the advices of Matt Thor, the CARDINAL rule in gluing fiberglass and/or resin parts is to use epoxy glues...but NOT, repeat, NOT of the quick driyng type, like 5-10 minutes epoxy.
    These quick cure epoxies AREN'T waterproof and will loose their strenght after a while...RC Submarines operate in a costantly wet environment.
    The best choiche for gluing fiberglass hull and resin parts is very slow cure epoxy glue (24 hours).
    Hope this helps!
    BEST REGARDS MAURO
    Edited By AdriaticSea on 1062835695
    • guardian
      • 18
      Thanks Mauro , now what
      Thanks Mauro , now what about glueing resin parts to fiberglass ?
      Thanks,
      Mike
