Re: 1/48 USS GRAYLING SSN-646 STURGEON BUILD
I use the Ventric 3D Cut program for the cutter paths.
This software (which is the easiest CNC software to use I have ever seen) takes
a STL file from Solidworks.
I then use the G-Code-Inch g-code selection for the output file for my Smithy 622 CNC machine.
Below are the steps I take to create the mold in Ventric 3D Cut.
As you can see, it does not get much easier than this.
