Sanding Epoxy
  • nelix6030
    • Dec 2003
    • 45
    Sanding Epoxy
    When using 2 part 30 minute epoxy and micro-balloons as filler, what grit sanding paper works best? Is it best to wet sand?
    Kyle
    sand wet !
    the dust
    sand wet !
    the dust is an irritant and goes everywhere.
    wet sanding keeps the dust manageable.
    a simple dust mask wouldn't hurt either.
      Kyle,
      I agree with Ronald....always wet
      Kyle,
      I agree with Ronald....always wet sand. It also will give you a better sanded finish.
      As for the grit to use, it depends on how much sanding you need to do. I typically start with either a 320- or 400-grit and work down to 600- and 1200-grit.
      It's best if you do some practice sanding to figure out what grits work best for you.
      • nelix6030
        • Dec 2003
        • 45
        ALways Great advice , Thanks
        Kyle
