Tadpole Sub! Yet another strange BD project!!
    I have been wanting to build one of these ever since seeing photos of one about a year ago.
    I am not sure what the design is called but I just call it the Mayo-Sub.
    (See bottom photo)
    Don’t ask me why I like it. I just think it is COOL!!
    Someone had quite an imagination.
    I was thinking it would make a great construction article to show that you can make a simple working sub with just cheap off the shelf parts.
    Having nothing to go by but a few photos I started to sketch out how I would build the design with in-house parts.
    Starting with acquiring a mayo jar. I finally grabbed one before it was tossed out.
    I did not want to use a glass jar so I went with a plastic version. For me using K&S brass tube and rod was a given!!
    My plan was to document the build and parts used and maybe get my friend Paul to draw me up some plans.
    Then if someone wanted to build one (if I can get it to work) they will have the information.
    This is what was done this afternoon in about three hours with designing as I went. It will use a simple 280 motor, two small servos, cheap ESC, and R/X. More to come. BD.
  • Larry Kuntz
    • 525
    Now that is a real
    Now that is a real Hellmann's sub!
    • crazy ivan
      • 659
      Man, I wish I had
      Man, I wish I had your kind of free time. Well, at least I can't see any visible screws holding it together.
      sigpic
      -George Protchenko
        Looks delicious. Should go well
        Looks delicious. Should go well with a submarine sandwich.
          You guys are making me
          You guys are making me hungry!! Knock it off will ya!!
          BTW-CI, I could always sneek in some screws somewhere if that makes you happy! BD.
            What did I start!?
            Is the
            What did I start!?
            Is the jar plastic or glass?
            • raf
              • Apr 2009
              • 25
              hallo
              a beter picture of the
              hallo
              a beter picture of the jar boat
              the plastic jar is not a good idea
              the plastic lid is also not so a good idea
              the rods are soldered into the lid
              you have 4 rods ? look at the picture again
              the motor is a 400 speed
              the glass jar is the ballast and the strips on the front is velcro
              the yar can punch and grab somethings with it
              the picture is taken last year in belgium zilvermeer
              the clubs location special for divers and submarines
              the page is in dutch but the movies are great
              http://users.telenet.be/moonen.hilda/ne ... tenmol.htm
              and more pictures
              http://users.telenet.be/kfmycb/submarines%20mol/ (press next)
              19 april is the next regatta day this year more pictures and movies to come
              greatings raf
                My jar is plastic Andy.
                Hi Raf,
                Thanks for the information.
                I see 4 rods. Here is a different photo.
                The jar as ballast is a good idea but I do not want to use glass as I will never be able to use it at the pools I run in.
                My rods have O-rings on the outside where they meet the cap. And the cap has been fitted with an O-ring to seal better.
                I am hoping the plastic will work OK. I may actually add some pressure to the inside to keep the plastic from crushing. It is a project so time will tell. Thanks again for posting the links. BD.
                • raf
                  • Apr 2009
                  • 25
                  hallo David
                  the fift rod is
                  hallo David
                  the fift rod is the axe if you look closely you kan see te prop on it
                  and the picture i posted on the inside you see the coupling in the center of the 4 outer rods
                  the two extra are for stearing
                  at the end you see one vertical support that runs from the top to the bottem rod but in the center it supports also the propchaft
                  4 support rods
                  1 propshaft
                  2 stearing rods
                  The original builder of this vehicle is dieudonne member of BMB
                  a belgium club from Brussels
                  COMMISSAIRE SOUS-MARINS:
                  Eugène DIEUDONNE (photo)
                  rue Genérai Molitor 12, 1040 BRUXELLES.
                  Tel. 02/733.50.62
                  he is responsible for the submarine section in brussels
                  on this website jou find more pictures of the jar boat
                  http://bmbwebmaster.magix.net/ ; select " le port en fete "
                  Regards Raf
                    Hi Raf,
                    I thought you
                    Hi Raf,
                    I thought you were just talking about the 4 outside rods. Sorry!
                    I do know the one for the prop shaft and the two control linkages need to be installed.
                    I have just not gotten to that step yet.
                    Did you need to install extra ballast? I do not see a battery but I would guess it is mounted on the inside tech rack.
                    This should be a fun sub to run. BD.
                    • raf
                      • Apr 2009
                      • 25
                      hallo david
                      the front support and
                      hallo david
                      the front support and the second IN the jar is plexyglas
                      and eugene has drilt some holes in them to support the battery's
                      and secured them wit tape
                      thats wat jou see on the front in the jar
                      on the bottom is a smal amount of lead to calibrate the sub
                      a norbert bruggen stabilliser is used to make navigate the sub a bit easyer
                      regards raf
                      • pirate
                        • 849
                        What a great idea just
                        What a great idea just for a WTC!
                        • redboat219
                          • Jan 2005
                          • 523
                          An appropriate name for it
                          An appropriate name for it would be The Tadpole
                          • raf
                            • Apr 2009
                            • 25
                            hallo
                            it's more like a drone
                            hallo
                            it's more like a drone of some kind of SF submarine
                            regards raf
                              while emptying a pot of
                              while emptying a pot of mayo is a tasty task, we should be able to
                              find even more attractive WTC's.
                              let's investigate this can of guinness....
                              obviously, a LOT of experimenting is called for
