Thanks Kevin for the pictures
Thanks Kevin for the pictures and information! Wow! I found that 1/2" PVC pipe weighed over twice more that 5/8" x .039 aluminium tubing for the same volume. For the schrader valve, I threaded it to 1/4-20 and threaded the 1/8" upper pressure disk. After threading and epoxying the valve, I cut the valve to within about 1/16" to prevent the epoxy going where I did not wish it to go and to reduce weight. Right now the tube, upper and lower disks, and valve weigh only .65 ounces. When completed with o-rings, paint, and fins it should be at about .75 ounces. Hope this helps with your missiles.
Best, Ed
Best, Ed
