Missile Construction Question
  • ramius-ii
    • 393
    Hi All!
    I have been trying to follow the June 1995 Issue 21 article by Mathew Spade on constructing missiles. In the article he writes "Next, drill a 1/6th inch hole in the bottom of the missile and slightly counter bore the hole." If my calculations are correct, 1/6th inch hole is .166 decimal or a #19 drill. This seems very large to me. Has anyone actually built a missile or missiles following this article and is this a correct and valid size hole or did I do something wrong?
    Thanks, Ed
    • 854
    Ed,
    1/16th inch is 0.062.
    B^)
    Ed,
    B^)
    • ramius-ii
      • 393
      Thanks and the article says
      Thanks and the article says one-sixth of an inch which seems very large.
        • 854
        Ed,
        I just reread the
        Ed,
        I just reread the article. I think we have a recurring typo for that fraction! Some thought food; There's butt-tons of 1/16 stock in our little universe and I suspect only two lengths of 1/6, stored somewhere in the vaults of Lower Slobovia. I also supect those pieces are made of Nonobtainium. ;^)
        If the hole (nozzle) in the bottom of the missile is much bigger than 1/16 you'll not get too very much thrust from the gas expanding through same.
        Take care,
        Bill
        • ramius-ii
          • 393
          Hi Bill! Thanks. Where I
          Hi Bill! Thanks. Where I get confused is when I look at the pictures in the article it looks just as you said, about 1/16th inches. I was given some Estes rocket motors (1/2A6-2) by my neighbor and the exhaust holes are about 1/6th of an inch! My intent is to incorporate the proper size o-ring in the tail of the missile as a seal against the "pin". Here is a drawing of the missile with a 1/6th hole. What do you think?
          Best, Ed
          • mike dory
            • Feb 2004
            • 158
            Give Matt a call
            Guy's - You might just give Matt a call. He's always been willing to help others. The last phone number I have for him is (770) 929-1945. You won't find a better man. Best Wishes..... Mike Dory
              • 854
              Ed,
              I thought you were
              Ed,
              I thought you were going with a gas ejection system. Matt and Dr. Art Broder have good experience with missiles. If you're going to use Estes motors, that's a whole different world. I remember years ago when Loren Perry burned the bow of his USS Long Beach (CGN-9) using the smallest Estes motors for A/A missiles. It was sad!!
              Good luck, I'm going back to sleep now!
              B^)
              • Rogue Sub
                • 1724
                I seem to remember watching
                I seem to remember watching a video where Mike was talking about how his rocket motor missile went through some lady's house and ruined her carpet.... Dont quote me.
                Bill I am the one using a gas ejection system.
                • ramius-ii
                  • 393
                  Hi Guys! http://www.subcommittee.com/forum/icon_smile.gif
                  Thanks to
                  Hi Guys!
                  Thanks to all. Yes, I am using a gas system and I was only looking at a rocket motor to see what size Estes used. The plan is to incorporate an 0-ring seal in the base of the missiles.
                  Best, Ed
                    • 854
                    Kevin,
                    I know you're using
                    Kevin,
                    I know you're using gas. That's why I'll have my trusty and faithful MK V mask with the heavy duty cartridges installed!!!!
                    B^)
                    • ramius-ii
                      • 393
                      Hi All!
                      First, thanks Mike I
                      Hi All!
                      First, thanks Mike I called Matt Spade, we had a great conversation and I learned a lot! He sends his greetings and best wishes to everyone. The answer is 3/32" or .09375. Matt started with 1/16" and found that 3/32" worked better. For all those developing missiles, one piece of valuable info is that a missile will work very different when launched from underwater than in plain air. "In plain air a missile will appear to be very disappointing, while launched from underwater will work amazingly!"
                      Best to All, Ed
                      • Rogue Sub
                        • 1724
                        As you may or may
                        As you may or may not know I have been makin a missile system for my ohio. Here is a look at how it works so far. I have been launching the missiles using 60psi and liquid air for propellant in the missile. The cylinders are 4" long and about 3"- 2.5" nominal gas space inside. Overall Missile length with balsa nose cone is 5". The exhaust port is 1/16" with a taper bore nozzle and o-ring seal. For my testing I am using air from my compressor to launch, later I will use propel on board, which has a pressure of about 70psi at around 70 degrees F. Right now I am test launching out of a bucket and getting small heights. To increase my height I am going to reduce weight by cutting down on bulkhead thickness. this will not only increase my gas volume but also decrease weight. A 3/32 nozzle is also interesting. Now for some photos and a movie!
                        Sorry If I jacked your thread Ramius I will move it if you like
                        [/youtube]
                        • Rogue Sub
                          • 1724
                          http://www.youtube.com/watch?v=guLXjlHFyCg
                            Kevin with increased gas volume....
                            Kevin with increased gas volume.... great....
                            • Rogue Sub
                              • 1724
                              Yeah believe it buddy as
                              Yeah believe it buddy as you type at this moment I am killing the dogs.
