A 1:144 AKULA I with a insiad RCABS ballast tank
W http://www.subcommittee.com/forum/icon_eek.gif W! C http://www.subcommittee.com/forum/icon_cool.gif
W
W! C
l model.
I've always wanted to see an Akula in 1/144 scale.
How about an Alfa or Delta III/IV in the same scale as a future build.
Aha! Maybe we will produce the Alfa or Delta III/IV in the same scale in futureW
W! C
l model.
lin
Lin,
I bet a Delta 4
KevinLin,
I bet a Delta 4 would be a very popular model.
How bout some closeups of the guts on the Akula.
How big is it?
Thanks for you suggest, but I can't understand]How bout some closeups of the guts on the Akula.[/u]
This AKULA size: Length 768mm, Beam: 80mm
lin
Inside RCABS
Can you provide drawings how your ballast system works. From what I can deduce from your pics your inside RCABS is like a Piston-based ballast system but instead of a rigid piston you're using an inflatable rubber diaphragm to push out the water. Is that correct?
Re: Inside RCABS
look at is demo photoCan you provide drawings how your ballast system works. From what I can deduce from your pics your inside RCABS is like a Piston-based ballast system but instead of a rigid piston you're using an inflatable rubber diaphragm to push out the water. Is that correct?
Lin
That's a very nice demo.
Aha!
Good idea!
That's easy, I can do it like your said. and I can extend the RCABS tank too. Thanks for your suggest
Lin
I've experimented with a piston
I've experimented with a piston using compressed air. It works, but something you need to bear in mind is the friction of the piston seal causes a bit of a delayed action, or in other words, the piston can carry on travelling along the bore for a little while after you stop the air pump.
This can make things a bit awkward if you're fine trimming. An alternative would be to try the same method, but use a bellows instead of a piston.
