I've experimented with a piston
Yes, that will be happen, but that relative small of my RCABS ballaste tank, so the piston will carry on travelling no along after you stop the air pump
I've experimented with a piston using compressed air. It works, but something you need to bear in mind is the friction of the piston seal causes a bit of a delayed action, or in other words, the piston can carry on travelling along the bore for a little while after you stop the air pump.
This can make things a bit awkward if you're fine trimming. An alternative would be to try the same method, but use a bellows instead of a piston.
