Flex drive on a sub
  • redboat219
    • Jan 2005
    • 523
    Flex drive on a sub
    Has anyone tried using a flex drive instead of a straight shaft on their sub's drivetrain?
  • petn7
    • Jun 2003
    • 616
    I saw some picture somewhere
    I saw some picture somewhere of someone who modified his SWM Blueback to use a "flex drive" coupling instead of universals or dogbones.
    • wolfsong
      • Jan 2005
      • 189
      because of using 1/4" prop
      because of using 1/4" prop shafts and 5/16" motor shafts on my typhoon and of still having some flexshafts, i made my own flex coupler with some octura adapters. works great and runs very smooth. the whole coupler assemply is about 4 inches long
      stefan
      • aeroengineer1
        • May 2005
        • 241
        Any problems with the flexshafts
        Any problems with the flexshafts rusting? Do you either use a different material such as stainless/brass or just careful maintenance? I am just asking because most of he flex shafts that I have seen are a regular steel.
        Adam
        • wolfsong
          • Jan 2005
          • 189
          im just using regular steel
          im just using regular steel flex-shafts.
          i do use a silicone based grease, that is sea-water- resistant .thin coat on the flex shaft worked so far for me
          stefan
