Caswell Snort System
  • redboat219
    • Jan 2005
    • 523
    Has anyone started using the snort system on their sub? Sure would like to see some pics or videos.
  • Rogue Sub
    • 1724
    Yes, I have been running
    Yes, I have been running it in my Akula. Works great saves gas. Win Win.
    • redboat219
      • Jan 2005
      • 523
      any video of it in
      any video of it in action? BTW, what's that thing on top of the wtc covered in silicone and has a bellow sticking out the side?
      • tommydeen
        • 327
        Interesting how does it work
        • Rogue Sub
          • 1724
          The yellow bellow thing is
          The yellow bellow thing is my solenoid for opening my ballast tank vent.
          The system doesnt really have anything to look at in video. All you will get is a picture with the added humm of the pump going.
          The system is simple. An air pump inside the wtc is controlled by either an electric switch or a servo/rocker switch setup. The a hole through the bulk head leads to the top of the ballast tank. This is your discharge. Another hole through the bulk head leads to the sail of the boat for your suction. You can see a bit of my house it is the grey stuff in the pics.
          After all that is installed you just plain the boat up a bit to get the suction out of the water and turn it on a few moments later it comes up. No check valves are needed due to the pumps design and if you make the the snorkel mast on the boat functional you could surface from full submersion.
          Kevin
          • sailman58
            • Jan 2008
            • 15
            How do you prevent the
            How do you prevent the intake from sucking water instead of air?
            • Rogue Sub
              • 1724
              You dont. No need really.
              You dont. No need really. Intermittent intake of water wont damage it. I wouldnt go running it underwater all the time though. If you get water it will just pump it to the ballast tank. This will not cause the boat to resubmerge because the air you pumped is already in there.
              • chuck chesney
                • Mar 2005
                • 176
                Nuke Power...where do you get
                Nuke Power...where do you get your solinoids? What brand, and how much do they cost? Same with the valves that the solinoids actuate.
                Thanks,
                  • 880
                  OK who is going to
                  OK who is going to try a rcabs snort system ?
                  -Scott
                  • Rogue Sub
                    • 1724
                    I cant see how that
                    I cant see how that would be beneficial....
                      I cant see how that
                      Agreed. These are two different ways to run a ballast system. One is self contained (RCABS and RCABS-R) and the other requires pulling air (e.g. snorting) from the surface (Snort system).
                      There are trade-offs, but both systems work.
                      • pirate
                        • 849
                        My new ballast system pulls
                        My new ballast system pulls the O2 from the water like a fish's gills, so no need for gas or a tank.
                        Amazing!
                        Pete
                          Pete,
                          I was wondering when you
                          Pete,
                          I was wondering when you were going to announce your new inverse fuel cell system!
                          • Rogue Sub
                            • 1724
                            As soon as I perfect
                            As soon as I perfect my gravitational field generator ballasting will be obsolete and it will drive through the water effortlessly!
                              I'm not a chemical engineer
                              I'm not a chemical engineer but, since I have retired, I have figured out a simple way to turn beer into urine!
                              Now I'm going to study fish gills to try to complicate the simple RCABS system!
