1/8 propeller
  • petn7
    • 616
    1/8 propeller
    Does anyone sell a modern nuclear propeller (skewed blades) that can be attached to a 1/8 shaft?
    Ships n' Things seem to have what I'm looking for, except the propeller is for 3/16 or M5 shafts.
  • petn7
    • 616
    As an alternative, is there
    As an alternative, is there a way to make an adapter to use a 3/16 propeller on a 1/8 shaft? If the propeller uses a set screw, would it be realistic to use brass or aluminum "sleeves" to widen the diameter of the 1/8 shaft to 3/16?
    • pier 72
      • Jun 2007
      • 140
      You might like to try
      You might like to try "Float A Boat" here in Australia.
      their link is http://www.floataboat.com.au/
      Dave
      • wingtip
        • Dec 2004
        • 336
        if your saying the propellar
        if your saying the propellar your wanting is for a 3/16shaft and is threaded 5m, ships n things does have that... i just ordered 3/16-m4 shafts and he nearly ordered them in 5m till i caught him mumbling and corrected him lol... i had to order 4 of those lil suckers and they were $18 each! arggggggggggggg
        • petn7
          • 616
          No, I just have a
          No, I just have a regular 1/8" shaft, but the propeller I want required 3/16" shafts.
          So I need a different propeller or a way to widen my 1/8" shaft.
            "As an alternative, is there
            "As an alternative, is there a way to make an adapter to use a 3/16 propeller on a 1/8 shaft? If the propeller uses a set screw, would it be realistic to use brass or aluminum "sleeves" to widen the diameter of the 1/8 shaft to 3/16?"
            I think you answered your own question. I have done that with brass tubing. I would suggest drilling holes through the brass tubing to line up with the set screw. The screw would then engage the 1/8" shaft directly, and there would be less of a chance for the prop to slip off.
            • petn7
              • 616
              Good deal, thanks for the confirmation and help.
              • Wheelerdealer
                • 315
                Also a 1/8 plain shaft
                Also a 1/8 plain shaft is close to the id of a M4 threaded prop. You could secure it with a drop of solder.
                • cstranc
                  • Mar 2007
                  • 158
                  A while back I was
                  A while back I was looking to do the same thing. When I phoned Ships 'N Things they had an adapter that would allow you to use a 3/16" prop on a 1/8" shaft.
                  It's been a couple of years now, so my memory may be off, but it might be worth the call or email to Al at Ships 'N Things.
