Brushless?
  • jr3d
    • Feb 2007
    • 13
    Sorry forgot to add this,
    Sorry forgot to add this, what is the largest static model alpha that I could get? I want to put more time than money in this thing and I just really don't want to pay 245 bucks for a hull, and what is a dry hull?
      Just to show my new
      Just to show my new brushless motor for the Dolphin boat. This is a FEIGAO 540-S 8 turn motor. I will be using a water cooling jacket as shown in the photo. The motor is good for about 55 AMPS of water churning power!!!! BD.
      • don prince
        • 201
        Does anybody know if you
        Does anybody know if you can use a bruskless motor in the wet space within the U-boat hull? I am considering using two brushless motors in my Type VIIc. Originally, I was considering a small Poly tube, but I did not consider heat dissipation. It wood be great if I could use the brushless motors in the wet space. cooling would be an added feature.... Hummm!
        Don_
        Harry Callahan, SFPD
          I personaly would not put
          I personaly would not put a motor in the wet section, but have never really tried. BD.
          • fgroza
            • Jun 2005
            • 168
            Look at Merrimans new micro
            Look at Merrimans new micro wtc for the Revell 212/214. It looks like he uses a outrunner that is in a wet condition. It is on the Caswell site.
            Frank
              Frank
              That's not made by Dave, it comes from China.
              • raalst
                • 1229
                my experience with wet runners
                my experience with wet runners (no experience with brushless) is that
                the ball bearings are the weak point. they typically rust.
                but cheap motors use bushings and they last.
                • fgroza
                  • Jun 2005
                  • 168
                  reversable esc
                  Check out FMhobbies for brushless esc's that have reverse. I just got a 10amp for $20 and it really works. Putting it into a 1/144 Revell 212 with a outrunner from Lazer toyz in Ohio.
                  Frank
