Robbe Typs XXI
  • salt6
    • Oct 2004
    • 32
    Robbe Typs XXI
    Ok, I'm finaly back and ready to finish this one. I"ve got the hull together and need to start on the WTC. Anyone got any tips to help me out?
    One thing I'm not to keen on is the setup for the forward sevos for the forward dive planes.
    Thanks,
    Why don't you post a
    Why don't you post a photos of what you've got so far - that should get the tips rolling in
    • mike dory
      • Feb 2004
      • 158
      Howdy - Regarding front diving
      Howdy - Regarding front diving planes on the Type XX1, On my 1/32 scale Type XXI, I found that in scale, they had very little effect in controling the boat diving. I would surmise, that this is in part due to their placement being back from the extreme forward area of the bow.
      Good Luck in your your project, Best Wishes Mike Dory
        • 342
        I'm at about the same
        I'm at about the same point on my build. If I was doing this from scratch I might do it differently, but since everything is included I can't see why not to do it their way.
        • salt6
          • Oct 2004
          • 32
          Man, just when I thought
          Man, just when I thought things were quiting down.
          Anyway here's a webpage with my build on it.
          the only things I didn't like is the front servo box and the rudder setup. I had an idea on how I want to do the rudder. I will do a mock up and see if it works. Then use it in the sub if it does.
            • 342
            Wow, didn't know that was
            Wow, didn't know that was you. I have used your building thread to inspire & guide me-it has been a long time since you have worked on the sub. Last night I put the front dive plane mechanism in place & have the retraction mechanism working well. The bow plane tilt linkage is too long & I am going to cut it & use a collar to make the length adjustable. If the linkage is not perfectly centered fore & aft it will bind when you retract it. Also, the original retraction servo arm was too short & I had to open the box up & change it. The Robbe pictures show the ball linkages on the last hole, there is not clearance for that & I drilled a new hole closer to the pivot to give enough movement.
            • salt6
              • Oct 2004
              • 32
              The big D got in
              The big D got in the way of things.
              • salt6
                • Oct 2004
                • 32
                One of the last things
                One of the last things I id before getting stalled and is not in the build thread. I glued some scrap onto the bottom and nose to strengthen the hull joints. I just sanded the edges down to blend with the hull.
                • mylo
                  • 723
                  salt6,
                  .......so......you were given the ultimatum
                  salt6,
                  .......so......you were given the ultimatum and.......you picked the sub.
                  Am I close ?
                  We should start a club.
                  Mylo
                  • salt6
                    • Oct 2004
                    • 32
                    More like I got custody.
                    • mylo
                      • 723
                      http://www.subcommittee.com/forum/icon_smile.gif
                      ....does she have visitation rights
                      ....does she have visitation rights ? , like maybe every other weekend ?
                      How about "Sub support", is she paying you ?
                      Mylo
                      • salt6
                        • Oct 2004
                        • 32
                        Well, I've been making progress,
                        Well, I've been making progress, slow but progress.
                        Anyway here what I did to the rudder.
