Hi Guys,
I am starting a new building thread I will be adding to from time to time.
I purchased a Sushi hull from Gantu and will be building it to compete in the Great Sub Races at this years Subregetta.
I am working now on the design of the operating system. My plan is to use a Bayonet sealing ring to open the hull. I am going to have X-Tail surfaces for maneuverability. The power system to start will be a 12 volt 540 motor turning a six-blade 55MM prop on direct drive. This is the same power train in the Engel Lafayette sub. I know how fast that sub is, so I think this little Sushi will fly. If not maybe a little Nitrous Oxide injection will help. Ha!!
Even though the sub is usually a dynamic diver I want to use a ballast system for a little easier control.
I am also planning to build a small piston tank, as I have always wanted to build one.
It will be a kind of having a bunch of ideas and changing them as you go kind of build. Which I enjoy!
This should be a fun sub to run, and I am looking foreword to blowing the doors off of a couple of Delphins at the Regatta. Here are a few photos. This is my bare hull, and one of the finished German subs. See Ya, BD.
