Periscopes - Lets get them working!!!
  • himszy
    • Nov 2004
    • 282
    #46
    I get it at 1000mm
    I get it at 1000mm x 50mm OD x 44mm ID for 5.95.
    Michael
    • paul von braun
      • Jun 2004
      • 242
      #47
      Where from?
      Where from?
      • himszy
        • Nov 2004
        • 282
        #48
        Paul,
        Did you manage to order
        Paul,
        Did you manage to order those tubes?
        Michael
        • bill marks
          • May 2003
          • 22
          #49
          Here is the periscope system
          Here is the periscope system I am experimenting with. It is hydraulic.
          As a diabetic, I have painfull access to small syringes. I found they work as perfect little hydraulic cylinders using water as the fluid and a little glo-fuel gear pump as the hydraulic pump.
          The whole system can be mounted inside of the WTC with the pump taking a suction "from the sea" and discharging to the syringe (less needle). When the scope is fuly extended, the pump just dead heads - no limit switches. The scope is lowered by reversing the pump and a very light spring that was stretched when the scope extended.
          Bill
          • boss subfixer
            • Aug 2004
            • 656
            #50
            Bill,
            Thats a neat idea. I
            Bill,
            Thats a neat idea. I was thinking awhile back about functional scopes for my fleet boat, when I get that far, and was curious how water would work. Lets face it the boat would have an endless supply and you would'nt have to worry about someone having a fit about putting oil in the water!
            • warpatroller
              • Feb 2006
              • 308
              #51
              This message is for Bill
              This message is for Bill Marks.
              Bill,
              I find your periscope actuation method interesting.. Have you actually tried this method out yet? Or is it simply just an idea you had.
              Steve
              PS. I worked with a diabetic for a year, and i remember watching him use his little syringes.
              • warpatroller
                • Feb 2006
                • 308
                #52
                I just saw in the
                I just saw in the General forum that your in the hospital.. I was unaware of that when I made the last post. I do wish you a very speedy recovery Bill!
                Steve
                  #53
                  Hi Bill,
                  I have tried your
                  Hi Bill,
                  I have tried your method and had it working at the Merstham show, here in the UK. It works very nicely. Hydraulics is much more rugged than electrical connections etc.
                  I used a 10ml syringe driven by a servo inside the WTC. The scope rests on a 4mm diameter floating PTFE piston in a brass tube.
                  I intend to write an article for our AMS magazine in the UK and I will give you all due credit for your idea.
                  Thanks and I'm so pleased to hear that you are recovering fast!
                  David Forrest
                  • shadowpeo
                    • 82
                    #54
                    Hi Bill,
                    I have tried your
                    Hi Bill,
                    David Forrest
                    You got any images of this setup?? sure sounds interesting.
                      #55
                      Here it is. Simple and
                      Here it is. Simple and effective. Thanks Bill! Get well soon.
                      David
                      • paul von braun
                        • Jun 2004
                        • 242
                        #56
                        David,
                        how do you keep the
                        David,
                        how do you keep the servo dry? How does the lead get to the reciever?
                        I saw this work at the Merstham show - was really good!
                        Paul.
                        • himszy
                          • Nov 2004
                          • 282
                          #57
                          Paul]I used a 10ml syringe
                          Paul]I used a 10ml syringe driven by a servo inside the WTC.[/quote]
                          David, (Too many Davids in this hobby)
                          How did you secure the syringe to the wood?
                          Michael
                            #58
                            Hi all,
                            I can see I
                            Hi all,
                            I can see I need to write that article for the AMS!
                            I should have explained that the servo is in the WTC and the piping just goes through a bulkhead connection. I tried waterproofing servos as per threads in this forum but I was not happy with the results. (Unkind to servos!)
                            I Dremelled a slot in the ply and put the "finger" tab of the syringe in this. Then tie wrapped it to the ply base.
                            Improvements?? A smaller syringe(2ml perhaps) and a smaller servo would give more space in the WTC.
                            David
                            • himszy
                              • Nov 2004
                              • 282
                              #59
                              Do you fill it with
                              Do you fill it with water or just use air?
                              Michael
                              • redboat219
                                • Jan 2005
                                • 523
                                #60
                                Davy,
                                That a very interesting
                                Davy,
                                That a very interesting piece of hardware you got there. I think you could use the same set-up as a piston tank in a small sub.
                                Romel
