Hi all
I was just wondering if anyone has any plans of a british t class. That shows the bulkhead's clearly i did purchase a plan of a t class from traplet publication's but it does not show anything regarding the frames/bulkhead's and the plan is on what only can be desribed as poor quality paper.
Regarding the sensor!
Im currently working on a project at college which is similar to probes that would be in the like's of a sealed ballast tank.
There is a sensor fixed to what ever height is required inside the ballast tank and above this is an led when the sensor detect's the reflection from the led it triggers the relay on the circuit board which then shut's down the power supply to the pump/speed control.
I just thought this might also work in other application's such as raising attenae and periscope etc. Anyone interestead i could probably scan the photomask onto the pc and email the design along with a list of components and there value's to you.
Dive sytem!
I've been reading about the Rcabs and the Rcabs-R
and was just wondering if they could be used in the same way people use the piston tank method for trimming
I,e if i had a central ballast tank and wanted to adjust the height of bow or stern could the Rcabs/Rcabs-r be used?
thanks and best regards
adam
Dive sytem!
adam
