Hi. I want to ask for your help in deciding the following...
I am putting all the internal pieces together in my WTC. I have the tube, stuffing boxes, UJ's, motors, and shafts.
My question is How do you put them all together, Bearing in mind my WTC is a Removeable tube ?
I can see the propshaft will have to end with a UJ which can be disengaged when the WTC is removed. So what does the other end of this UJ fix to? - The motor spindle is not long enough to reach through the end cap and stuffing box. So presumably another length of propshaft will have to extend from the external UJ in through the stuffing box and then be connected to the motor via another UJ on the inside???
Does this sound right - Two sets of UJ, one inside the WTC and one Outside?
I think I am a bit lost.. my last method was a fixed pressure hull so I only needed One UJ connecting the motor to the shaft which then went down a greased shaft.
Any light you can shed will be much appreciated.
