Hi Big Dave,
I posted a
Hi Big Dave,
I posted a "Reguest For Comment" on my own design of a high pressure dive system, and George "Crazy Ivan" sank my sub! That's OK, I didn't mind, because he provided good information and suggested another dive system similar to yours. However, I guess I will have to build it on my own since it's for a much larger U-Boat. Besides, I have plenty of time on my hands...
I noticed you have a small plug on the endcap of the air chamber. If you start with a empty chamber at atmospheric pressure and fully inflate the bladder, then what is the internal negative pressure in the chamber? What is the air pressure in the bladder? What is the PSI rating on your airpump? Is it a reversible pump with a check solenoid valve?
I hope that I'm not asking about any trade secrets... I would just like to understand the basic principles of your dive system. I like to play around with IC packs [NAND, OR, SS-Relays, etc.] and have done a basic circuit layout to control an air pump and limit the bladder pressure to a set PSI (pressure sensor). When the bladder is to be deflated, a negative pressure (vacuum sensor) sensor will shut off the air pump as well. My circuit includes a missing pulse input which will run the pump and inflate the bladder, and a battery low input that does the same.
Don_
Edited By Don Prince on 1133911328
I posted a
Hi Big Dave,
Don_
