From surfaced to neutral submerged
From surfaced to neutral submerged trim, the displacement of the entire boat never changes. The overall weight of the boat never changes. The displacement IS the bouyant force and it always equals the entire weight of the boat. The boat, as a dynamic system, will seek to correct an imbalance imposed upon it, such as a ballast tank being filled or emptied.
If the boat is submerged at neutral trim and you blow the tank, the weight of the boat has not changed, you've just added 500cc to the displacement. BUT, displacement is constant, so the boat pops 500cc out above the surface to eliminate the "extra" displacement you just added. Then the boat is once again in equilibrium. But nothing ever really changed, not the weight, and not the displacement.
The mass (or weight) of the section that popped out is immaterial, because that part weighed the same in air or water; it's always been pushing down on the boat with the same force. The boat just needs to equalize the displacement that you upset, but the weight of the boat never changed.
Thinking of the boat as "heavier" after taking on water is really not correct, IMHO. The water (while underwater) weighs zero, so only the reduction in displacement should be considered. The system will equalize based on displacement, which is only a volumetric calculation. Converting to force based on water density is misleading. You can convert the entire boat's new displacement to force, and you'll find it's unchanged and still exactly equals the weight of the boat.
This exercise has really changed my mind on this topic. I started making those graphics to prove my earlier statement was correct, but it surely backfired on me.
