Mylo,
you don't need 30% of
Mylo,
you don't need 30% of the sub's dry weight in variable flotation.
the only flotation you need is the weight of the material above the waterline. that depends entirely on the hull you are modeling.
my model has a very low surfaced profile. its variable flotation is only 5% of its total weight.
the weight of all that material in your case might in fact be 30% of the weight of the empty fiberglass hull, but not 30% of the dry weight of the entire boat.
dry weight of the entire boat includes everything. the Hull, the WTC, the contents of the WTC, the batteries, the keel weight, the flotation foam... etc.
Tim
Mylo,
Tim
