Motor Works Seawolf Sighting
  • mike byers
    • May 2003
    • 103
    Found a Motorworks Seawolf today at the Walmart in Manassas, Virginia.
    $19.99.
  • collins class
    • Dec 2004
    • 128
    Motorworks Seawolf....
    http://www.geocities.com/byzcol/b0_1_b.jpg
    • turbobearcat
      • Apr 2003
      • 404
      I'm heading to Owensboro Ky
      I'm heading to Owensboro Ky Saturday, I was told they have 4 in stock So I will get to post something about this gem soon..
      Mark
      • turbobearcat
        • Apr 2003
        • 404
        OK I can now see
        OK I can now see there has been changes done to the Seawolf vers the older LA class boats..
        the Hull on the SW is fatter in diameter than the Dallas and the sail
        is smaller and the the pumpjet screw is shrouded and not inside the hull as in the past subs. I seen that Motorworks has also made the turning motor props 3 bladed compared to the 2 blades on the LA class subs.. I hope to get out and do some testing soon, this might
        be fun! ok..that was stupid to say..we know it's fun!
        Mark
        • gerwalk
          • Dec 2004
          • 525
          What about the electronics? They
          What about the electronics? They improved them? The latest LA boats had faulty electronics (I know that that can fixed)
          • turbobearcat
            • Apr 2003
            • 404
            From what I seen tonight, I believe this is a good improvement
            over the old DAllas boat...and I am planning some mods NOW for the Seawolf.
            Pictures and comparing the two will be coming up soon..
            Let's just say a Stock Seawolf and a slightly modded Dallas are a good match against the other..when I mod the Seawolf, she will be the one to beat.
            Mark
            • desert boat
              • 195
              Got my Seawolf tonight ...
              Got my Seawolf tonight ... my Walmart had three each of them - SW and the Conn(however you spell it).
              • turbobearcat
                • Apr 2003
                • 404
                http://img.photobucket.com/albums/v331/Turbobearcat/9ba0c7e3.jpg
                http://img.photobucket.com/albums/v331/Turbobearcat/d43df044.jpg
                http://img.photobucket.com/albums/v331/Turbobearcat/1f1d9bda.jpg
                http://img.photobucket.com/albums/v331/Turbobearcat/492
                notice the changes made and the hull shape..
                Mark
                • novagator
                  • Aug 2003
                  • 820
                  How do they run.
                  How do they run.
                  • turbobearcat
                    • Apr 2003
                    • 404
                    How do they run.
                    Well the
                    How do they run.
                    Well the Seawolf will run circles around a unmodified Dallas and a modded Dallas runs about the same speed as a Seawolf that has not been modded.. so theis Wally Sub is a good improvement over
                    it's older sibling.
                    Mark
                      What kind of control system
                      What kind of control system are they using.?
                      The controls don't look proportional- are they bang-bang?
                      Also does the sub have servos, or does it feature actuators?
                      I suppose you can't expect too much for just over a tenner, but I'd be interested to know just the same.
                      • turbobearcat
                        • Apr 2003
                        • 404
                        If you look at the
                        If you look at the picture of the subs, you will notice a fan duct
                        that does from the top to bottom of the sub, that helps it dive from a stand still and then near the rear you have two props with the same setup that pushes the stern left or right..kinda like a pumpjet for steering or diving...
                        Mark
                        • turbobearcat
                          • Apr 2003
                          • 404
                          If you look at the
                          Mark
                          I have an update coming up.....
                          • turbobearcat
                            • Apr 2003
                            • 404
                            If you look at the
                            Mark
                            The Update is the Seawolf sunk after 20 minutes in the water
                            and I have no way or recovering her
                            it's about 15 feet from shore when I did one more dive...that one more dive must have pinned her on something, she won't surface..
                            Not good...
                            • turbobearcat
                              • Apr 2003
                              • 404
                              OK A NEW Seawolf was
                              OK A NEW Seawolf was put into service and I did manage to get some play time into it, make sure nothing leaked and the balance
                              was made good. Also did one mod which is a MUST DO for this sub.
                              take the rear diving planed and cut the tabs off that holds it to the hull.. use Marine Goop and stick them back on but angled up by 20 degrees.. this seems to work well in the pond.
                              Hmmm more test coming..
                              I have more time now since I'm winding down the end of the car projects.
                              Mark
