volume calculation - having trouble caluculating the volume
  • gof
    • May 2005
    • 18
    hi fellow members
    i am new to rc submarines so i brought the book called model submarine technology which i found out to be very informative on the subject and helped me to decide to build rc subs.
    one of the problems i am having is that on page 18 of this book they give you formulars to calculate 1.hemispheres 2.cylinders and 3.truncated cones.
    the problem is that the formulars that they have given you ,it seas that the bigger as the cylinder is the smaller the volume is so can any one point me in the right direction for the right formulars to calculate the volume of these objects
  • jsl
    • Oct 2004
    • 64
    Volume of a cylinder is
    Volume of a cylinder is the easy one]http://www.subcommittee.com/forum/icon_razz.gif[/img]
    The two above volume calculation formula should be correct. Do give me a heads up if I'm mistaken.
    • gof
      • May 2005
      • 18
      thanks JSL i thought i
      thanks JSL i thought i was going mad
      • jdbostrom
        • Mar 2005
        • 135
        If I am not mistaken,
        If I am not mistaken, the formula for the volume of a cone is as follows]http://www.subcommittee.com/forum/icon_razz.gif[/img]
          Hi Jonathan Bostrom please try
          Hi Jonathan Bostrom please try this program.
          Gantu
          • jdbostrom
            • Mar 2005
            • 135
            Before I download it, could
            Before I download it, could you please explain exactly what this program is?
            • boatbuilder1
              • 386
              I downloaded this gem but
              I downloaded this gem but it will not run do I need a language translator or what please help
              and here are is the method I use
              weigh or estimate everything above the waterline, always err on the lighter side (lead ballast can cure this) in ounces and divide by 0.58. this will convert weight into volume of water in cubic inches.
              • aeroengineer1
                • May 2005
                • 241
                The value for Pi is
                The value for Pi is slightly off; it is 3.14159265...... Ok, so perhaps I gave too many digits. Also I am just confirming that the volume of a cone is v=1/3*pi*r^2*h
                • gof
                  • May 2005
                  • 18
                  thanks aeroengineer1 http://www.subcommittee.com/forum/icon_smile.gif
                  the formular that
                  the formular that im looking for is for a truncated cone
                  a cone that has had the top cut off it
                  regards
                  lee
                    Well that isn't difficult.
                    All you
                    All you need to do is draw the cone as if it isn't truncated at the top, work out the volume with the formula, make a note of the result.
                    Then draw a line across where the truncation is, and you will have a smaller cone above. Work out the volume of that cone, and make a note of that.
                    Now all you have to do is subtract the volume of the smaller cone from the larger cone, and voila you have the volume of your truncated cone.
                    Edited By Sub culture on 1117097194
                    • fx models
                      • 166
                      Gantu
                      The version you link to is an expired beta version... Have the link to the right version by chance?
                      Marc
                      • bograt
                        • May 2005
                        • 6
                        Hi All ,
                        Thought you might
                        Hi All ,
                        Thought you might find this link usefull , it contains everything you should remember from school , but most of us don't !
                        A library of Online Calculators ranging from household, commercial, educational, financial, betting and IT calculations.
                        Bograt
