Hi Nick,
Glad that you were
Hi Nick,
Glad that you were able to contact Engels regarding the manuals that you need. Regarding the tubing that you will use...relax, it's just garden variety vinyl tubing. Just be sure that it doesn't kink on you. I inserted stainless steel coiled springs about the same size as the ID on the tube to make sure that kinking was not going to happen.
One of the problems with the piston tank ballast system is that every time you suck water into the tanks, you are also importing EVERYTHING that is in the water through the plumbing and into the tanks...grit, weeds and junk in the water can be a problem, particularly if it gets clogged in the tubing.
An advantage with the piston system is that you can trim the boat for neutral boyancy much more easily than any other type of ballast system that I know of. It becomes a matter of personal taste if that is important to you. I have never thought it too important to be able to make my boats hover, submerged. What you end up with is a submerged boat, that you can't see, doing nothing and going nowhere. Rocks in the pond do that already.
Having a couple of decades of experience with the piston system, and a year or so with the RECABS system, I'll take the RECABS every time. The whole WTC isn't very much bigger than a single piston tank with its motor/reduction gears, uses about three quarters of an amp @5volts to blow ballast, taking about 15 seconds, does not use outside air or water, does not require a slab of steel ballast and can be moved from hull to hull with ease.
I'll put together a couple of websites about model subs, and post them or send them directly to you.
Glad that you were
Hi Nick,
