Fiberglast 60-min epoxy resin - OK to use?
    ...searching for a decent epoxy resin to use for joining hull parts, creating indexing strips, etc. Has anyone used Fiberglast's 60-minute hardener with their System 2000 epoxy resins? Is this adequately waterproof over time and strong enough for r/c use?
    thanks
    e.
  • yellowdog
    • Jul 2004
    • 55
    I have been told by
    I have been told by some very good builders that the shorter the set up time, the less water proof your lay up will be. I use West Systems epoxy and have gotten great results.
    Later, Dan
    • wingtip
      • Dec 2004
      • 336
      ouch, hate to hear that,
      ouch, hate to hear that, i just glued my stuffing boxes into my wtc with 5 minute epoxy lol.... oh well, live and learn...
      • novagator
        • 820
        I just use the stuff
        I just use the stuff my local hobby shop has.
          I prefer to use a
          I prefer to use a 90-minute or greater epoxy for the miscellaneous work. I've had some problems with the 60-minute (and less) epoxies.
          For work where large amounts of epoxy are needed, I too prefer the West Systems products.
            Jeff,
            any particular West product number?
            Jeff,
              Erich,
              I use the #105 Epoxy
              Erich,
              I use the #105 Epoxy resin and the #206 Hardener....though the #205 Hardener will work just as well.
              • boatbuilder1
                • 386
                I think I have said
                I think I have said this a few times but here we go again
                listen up students there will be a test
                this should be your creed
                " the longer the cure the stronger the bond!"
                NEVER USE 5 MIN EPOXY IT WILL EMULSIFY IN WATER
                IMHO
                pc7 pc 11 marine grade epoxy is a two part paste and can be nuc'ed in the Mike to achieve a lower viscosity for easyer use.
                if you are intent on using off the shelf epoxy use 45 minuet or 1slow cure, a new glue on the market is gorilla glue and it works great. one other glue is elmers probond polyurethane glue it has a 24 hour cure time and once it is mixxed you can not touch until fuly cured
                lesson over
                chuck
                  ...i think i just got
                  ...i think i just got schooled
                    I was wondering if anyone
                    I was wondering if anyone had ever tried the Gorilla glue for boat and sub modeling. It is supposed to be totaly water proof. I will have to test it and see.
                    • boatbuilder1
                      • 386
                      we live near the marina
                      we live near the marina and some of the local small boat owners say its a miracle glue
                      • georget
                        • Mar 2004
                        • 74
                        #### Chuck, you the man!
                        #### Chuck, you the man! Lesson duely noted.
                        George
                          I tried a bottle of
                          I tried a bottle of it and put it away - at least for my modeling purposes.
                          It IS very strong, but it keeps expanding for some time after application. It foams to several times its original volume and runs all over, making a yellow mess that is difficult to clean up. I found it not good for the small stuff I work on where neatness counts ten points.
                          Don't just take my word for it, do a Google search on "Review Gorilla Glue".
