then spend as many weeks as you need to in order to read the relatively thick owners manual to figure out how to mix as many channels as you need to....
im using a JR8103 which has a ton of mixing functions...its not hard... i dont think you need to also mix the dive planes untill after you have the shaft mixes done and ran a few times to see if you even need a dive plane mix... but its easy to do with a little reading if you forgot the programming lol...
Get a Vantec RDFR ESC. The RDFR21 is the cheapest at $239.95.
now... say on port turn, do i also need to mix the diveplanes so the port would go up and the starboard down ??
Are you thinking of using the stern planes like ailerons on an airplane? I don't think that will work real good, especially with a TYPHOON - you'll be pitching the bow up or down with the turn. It's better to use a little up plane, if needed, in a turn.
