Fiberglass repairs
  • themongoose_OLD
    • Jan 2005
    • 26
    Fiberglass repairs
    Can I just make minor repairs..like where the drill went into the glass...with some standard fiberglass resin?
  • chips
    • 498
    Yes, you can make minor
    Yes, you can make minor repairs with standard fiberglass resin (like the Bondo brand at most auto parts stores). If it's a minor defect, like a dimple from a drill bit or a deep scratch, you could use some auto body putty or spot glazing putty (Bondo red putty).
    Edited By chips on 1107923716
    • wayne frey
      • 925
      I filled in 80 something
      I filled in 80 something holes on my Alfa to move the flood hole locations.
      I tried laying wax paper on the outside,then taping it to the hull.Then I went on the inside and mixed up some microballons and epoxy resin (love that stuff).Put a relly small piece of matt cloth in the hole after putting the mix in first.Use a toothpick to apply. When finished, it usually comes out pretty good.Be sure and get any airpockets out before it drys.
