Problem with the control rods in the - control surfaces.
  • novagator
    • 820
    control surfaces. Every time I CA the rods into the rudders and dive planes, they stay for a while and as soon as I hook up the control linkages the rods break from from the glue and then its back to square one.
    Is there a trick to getting them to stay glued in the control surfaces.
    I have a Thor Alfa if that helps.
    Hi John,
    Could provide a few
    Hi John,
    Could provide a few more details? It's not clear (to me) what or how you are CA'ing the control rods into the control surfaces....or why!
    Are you perhaps referring to the 'pivot' rods that are embedded in them? (and not the servo control rods?)
    If that is the case, it almost sounds like you are getting too much force applied to them. The CA will hold under normal use, but it can be 'popped' loose.
    Some a boat as large as the 1/72nd Alfa, my preference is to use a piece of square rod which is embedded in the control surface. The size of the square piece is such that it rides inside a round bushing installed in the hull.
    • chips
      • 498
      Clean the control rod surface
      Clean the control rod surface with some 400 wet-or-dry sandpaper (used dry) to remove all glue residue, tarnish, corrosion, etc. DO NOT touch the cleaned surface with your bare hands - the natural oils in your skin can cause the glue not to stick. Before applying the glue, wipe the sanded portion of the rod with some rubbing alcohol, this will also help remove any impurities.
      • thordesign
        • 343
        grind the rods with your
        grind the rods with your dremel tool and epoxy them in.
        • novagator
          • 820
          thanks guys
          thanks guys
          • don prince
            • 201
            I had the exact same
            I had the exact same problem with my OTW 1/32 Scale U-boat (U-96)... I had 3 out of 4 shafts break loose from the control surfacses even before the hull was completed (Port and Starboard front hydroplane and 1 of the dual rudders). Since I was an "Old Timer" who works for the National Cash Register Company for many years, I was very familiar with how to perminately bond a device to a metal shaft. The fix is to pin the surface to the shaft.
            What I did was drilled two small holes through each control surface and the metal control shaft. Now you can CA the shaft to the control surface and drive a small nail into the two drilled holes. A little CA around each end of the nail near the surface. Then use a Dremel grinding wheel to make the nail flush with the control surface.
            This is my perminate solution that works really well...
            Don_
            Harry Callahan, SFPD
            • novagator
              • 820
              Well I got 3 to
              Well I got 3 to work, going to wait till tomorrow to test the 4th since I just glued it in.
              • wayne frey
                • 925
                Novigator,
                I emailed you tonight,but
                Novigator,
                I emailed you tonight,but it bounced back. Did you change something?
                • novagator
                  • 820
                  Novigator,
                  Novigator,
                  Wayne,
                  My hotmail account might be full. Keep the same address, but change @hotmail.com to @gmail.com Taht should work. With over 1 gig of storage you can't beat it.
                  John
