WTC securing to hull
  • paul von braun
    • Jun 2004
    • 242
    Dear all, how does one go about securing the WTC to the inside of the hull?
    Paul Brown.
  • fung pang
    • 91
    velcro!
    see post for the kilo.
    velcro!
    • paul von braun
      • Jun 2004
      • 242
      Does velcro work in a
      Does velcro work in a wet environment?
      • petn7
        • 616
        i think so; i don't
        i think so; i don't see why not.
        • bradv
          • Jan 2004
          • 129
          Velco works great U/W -
          Velco works great U/W - it's what holds the top of the hull onto my Dumas Akula! Actually takes quite some force to remove. Even the adhesive on the back of the velco if fairly water-proof. I've only had to add a small drop of CyA to each end of the velcro strips to keep them from lifting.
          • captain nemo12
            • Sep 2003
            • 279
            I use latches, they work
            I use latches, they work well and are easy to secure against each other.
              Velcro works, But I usually
              Velcro works, But I usually like to use tie wraps. Cheap, replaceable, and not as prone to loosining.
                try rubber bands, like most
                try rubber bands, like most of us...
                  I just put a top
                  I just put a top on my mounting brackets and screw it down snugly]http://www.rc-sub.com/images/modelpics/finwtc3.jpg[/img]
                  Since this pic was taken, I've modified my cradles so that I can drop mt WTC into place from the top instead of sliding it in along the bottom (but you get the idea).
