Ballast pump wiring
  • paul von braun
    • Jun 2004
    • 242
    Ballast pump wiring
    [color=#000000]Dear all,
    next problem - does anyone have any suggestions on how to wire the reversing circuit for my geared water pump utilising two microswitches? I am stumped, and I think that I actually need to use four. By reversing circuit I mean that the switches are actuated by a servo thus]
  • thierryc
    • 162
    This will probably help]http://sub-systems.dyndns.org/forum/MAG.gif
    This will probably help]http://sub-systems.dyndns.org/forum/MAG[/img][1].gif
    • paul von braun
      • Jun 2004
      • 242
      Thierry,
      thanks for the advice
      Thierry,
      thanks for the advice - looks to be a master stroke on your part! Where did you get the info for that?
      Paul.
      • ramius-ii
        • 393
        Hi Paul]http://www.subcommittee.com/forum/icon_question.gif As I see
        Hi Paul]http://www.subcommittee.com/forum/icon_question.gif[/img] As I see it, you have fast fill and fast empty. With a speed controller you could would have an adjustable rate.
        Best, Ed
          I agree with Ramius. An
          I agree with Ramius. An electronic speed controller with either a servo controlled valve or magnetic solenoid would be a better choice than micro switches.
          The latter can be a source of trouble.
          • paul von braun
            • Jun 2004
            • 242
            The latter can be a
            Andy,
            A source of trouble? What sort of trouble?
            Paul.
              Electro-mechanical switches have a marked
              Electro-mechanical switches have a marked tendency to fail, for all sorts of reasons, often when it's most inconvenient!
              An electronic switch, although seemingly more complex, is much better alternative- trust me I'm speaking from experience.
