boat lifter/launcher
    • 370
    I had a couple of questions at Carmel about my boat launcher. I looked through my old posts and the directions/images are gone so I am reposting. It is made from 1/2" copper pipe and where the boats rest is wrapped in rubber electrical tape. The sizes listed are for what suited my needs and can easily be changed to whatever works for you. One other thing to note is that there are 2 common wall thicknesses for water pipe I used the thicker for mine as I have some heavier surface boats that use it too.
    https://www.homedepot.com/p/165-lbs-...0531/316261785
      • 1501
      Greg
      Thanks for bringing the boat launcher to Carmel. I used it to get the
      Boone and the Shark out of the water.
        • 342
        Thanks for the launcher! Was good for my boats
          • 349
          One alternative to the tape is to zip tie on some of the hollow foam pipe insulation. The joints are just soldered, a small torch makes quick work of it. Very handy at pondside!
          • Rick Teskey
            • 217
            Looks a bit like my basic design
              • 370
              It should look like yours Rick I based it on your design with some mods to work with some of my other boats, Greg
