No more cup seals, bellows, or o-rings! My Magnetic End Cap
    • 2354
    Years ago, I played with a magnet connector for my prop shaft. It did not work for me. It kept slipping and did not have that gription (not a real word, but I like it). Recently, a gentleman named Nick, made one that he liked. That got me back to thinking about it again and using magnets for the drive line and while I am at it, the pushrods too. I think my issue before was woefully too weak of magnets, but did not feel like spending more time or money on it. So, this time around, I injected some testosterone into the mix (think "Home Improvement"). To add to this, technology has changed, we now have 3D printing and I can now express my thoughts better into a tangible result.
    Here is the 3.5” prototype, In the center is the geared magnetic drive. The rod coming out of the hole is attached to a cylinder magnet.
    With everything removed, There is a nipple in the center that a bearing rides on. In this prototype there are 3 holes that are more like cups in that it is sealed at the end. What is missing (and will be put in the next print) is the water intake for the piston.
    This is the wet side showing the three cups or sealed tubes that the magnet moves inside. Also like the dry side there is a nipple here too. I am concerned the cylinders getting broken. However making the tubes go inward rather than outward adds more issues that I might need to tackle if these are too vulnerable.
    A side view of the assembly put together. I needed to drill out the cylinders a little to make the movement smooth with the internal magnet. The outside needed a little bit of sanding to knock out the nibs of the supports. However, the motion and strength of these magnets is really good. Maybe too much strength, but really pleased with the outcome.
    This shows the magnet used on the wet side and the pushrod magnet from the dry side.
    Another shot without the dry side pushrod magnet.
    The geared magnet drive is setup with a bearing in the center and 4 magnets. The nipple will rest on the center ring of the bearing. the outer surface of the bearing is affixed to the drive. As it rotates it will spin freely.
    The wet side is identical to the dry just designed to attach to a 3/16” shaft to the prop.
    Issues - I made the nipples a little too small. I was being very conservative and trying to keep the distance as close as possible. However, once the magnets came in I realized (well tested) even with 5mm of resin between the magnets they held up. So, I know if threes an issue with the thinner wall, I can add more thickness to it. You can see in the photos that they are rubbing against the end cap. For giggles, I will drill out the nipple and insert a brass rod to see how it rides.
    Pretty cool, Tom! Mag drive pumps have been using this technology for nearly 50 years. It works really well as long as you can keep the magnets properly lined up. Sometimes the pump couplings will "jump" of their associated magnet on the other side and require a mechanical reset to re-align the system. The way you have this system set up should take care of that. Nice work!
      • 2354
      Thanks Matt!
      The idea of using magnets like this has been around for a long time and even for our hobby it has been done before. There are not too many new ideas, but we build off what others have started.
      I love the ability to try things out and keep my brain going.
      • Jakub
        • May 2021
        • 34
        A deep dive WTC cap! Nicely done, the pushrod idea is especially brilliant.
        I did experiment with such magnetic clutches/seals some time ago too, but encountered an issue - the motor began taking a lot more amps from the battery. It was caused by the strong rare earth magnets influencing the motor's magnetic field. This was issue number 1. Sadly issue number 1 caused a bigger issue - number 2 - those additional amps had to go somewhere, if they didn't go into speed or torque... They obviously went straight into heat. Of course this can most likely can be avoided by a proper distance between the motor and the magnetic clutch/seal, but it's worth for you to keep an eye on.
        My knowledge base and blog:
        www.RCshipyard.com
          • 2354
          Jakub,
          Thank you, that will be the next hurdle. I am certain there will be many versions before or if this will work well enough to put in a boat.
            • 851
            What will take into account the slippage from answering a Back Emergency bell?? That one gets used a lot during Fun Runs and Regattas!!
              The magnetic interference issue can be handled by increasing the distance from motor to clutch.
              Say put the servos between the motor and clutch.
              And then using steel sheet to make a barrier between the motor, servos and clutch.
              Steel soup can lids will stop magnetic lines of flux and not add too much weight.
              • MSM
                • Aug 2020
                • 1
                Nice work Tom! I think you may have saw this video that I posted before with the magnetic clutch drives I recently made.
                Thought I had a video on my YouTube channel demonstrating the slip clutches slipping when I physically stalled the shafts showing the difference in amperage draw but I think I may have posted that video directly from my phone to the Subcommittee Facebook page.
                Anyways they work awesome with no additional amperage draw, no problems with the brushless motors and no problem going full ahead to full astern in emergencies.
                Keep up the awesome work buddy. I like where you are going with this!
                Nick
                  • 2354
                  Nick,
                  You got me going down this path again so thank you!
                  I am using a brushed motor, but maybe move to brushless later. Nick, I follow all you do, love your thinking.
                  • coryhenry
                    • Jun 2020
                    • 107
                    Tom, It appears your PM inbox is full
                      • 2354
                      Cleared out some messages, thank you Cory!
                        • 2354
                        Bill,
                        The magnets I put in, may not have any slippage (well that is not 100% accurate)…..I might have used too strong a magnet. Testing is coming up soon.
                          • 2354
                          Ralph,
                          That may be needed, will know more in time. Thank you!
                          See you pond side Saturday.
                            • 611
                            I see the headline...
                            Nevada man builds Magnetar, local RC group falls into spatial rift!
                              • 2354
                              Did some assembly on the end cap. Very pleased. Will be mounting motor and running some tests......Photos will be coming.
