Futaba 75mhz AM attack 4 transmitter.
  • cheapsub
    • Feb 2011
    • 200
    Can I see show off hand, how many of you still using the radio, or has one but no receiver. Thank you.
    Hitec count too.
    I have 2.
    I have 2 Atttack 75 hmz and 2 Attack 72 mhz.
    None in use but considereing one 75 mhz for surface boat.
      I have several in use. Those are some of the best radios Futaba produced. They were simple, reliable, and can REALLY take a beating.
      I, also, have nearly a dozen on my shelf waiting for use.
      • cheapsub
        • Feb 2011
        • 200
        Finded a way to turn some futaba AM 2ch receiver to 4ch, there is 3 big lot of them in evil bay. Anyone want some for backup?
        After I xxxx with it.
        • cheapsub
          • Feb 2011
          • 200
          NO!....... DAMNN YOU GOOGLE.
          4/16に発令された全国の緊急事態宣言から3週間ほど経過しようとしていますが、いかがお過ごしでしょうか? 仕事の方は震災の時の計画停電並みにGW休暇が増えました。 緊急事態宣言が延長されましたが仕事の方は在宅が継続かな? STAY HOMEと言われていますのでおとなしく家
          Ware on earth I find a 7 channel AM receiver now!
          Not EVIL bay again.
          • cheapsub
            • Feb 2011
            • 200
            Just to make things worse.
            • cheapsub
              • Feb 2011
              • 200
              Warning this is for your entertainment Only, if you fall off your chair it's not my fault.
              Please don't try this at home, l needed to kill time and some brain cells.
              Before
              Removed pins
              Cut trace
              The 2 PWM pins need to reconnected
              Jumper
              Top jumper wire.
              Another Frankenstein receiver. Done!
              Another receiver
              Instead of 4 channel I may make it to a 8 channel receiver.
              But have to make a 8 channel transmitter.
              • cheapsub
                • Feb 2011
                • 200
                Got my hand on some skysport 4.
                KEEP the Attack 4!
                Skysport 6 that is another story.
