What's on your winter bench?
    Well, the end of summer running in most of the country is coming to a quick end.
    What's on your winter work bench this year? Any new projects? Fixing up a veteran boat? Any scratch builds coming up?
    I hope we see some boats we've never seen modeled in the past.
    Just to start the conversation, my list includes gutting and reworking my 1:72 Connecticut, assembling an Engel Lafayette, and more work on a couple 3D printed projects. If at all possible I'd also like to put a small dent in the Arkmodel Type VII.
    • 1453
    Sounds great Erich. If you have any questions on the Lafayette or would like some pics
    of the tech rack, let me know.
    • chips
      • 494
      Finish up my 1/96th scale USCG 327' WHEC. After that, I'll make some brass drive coupling sockets for my Revell 1/72nd scale Type VII. One of the Alumalite ones cracked at the Carmel Sub Run - pictured below. After that, I might actually finish the mahogany runabout I started a few years ago.
ID:	133721 Click image for larger version
      • Davidh
        • Feb 2016
        • 74
        What, Winter?
        We are just coming out of winter and already we are having bushfires in August!
        Trying to wrap up and get the tooling done for my new Project 667 BDRM Delta 4 SSBN.
        I would like to get this boat in the water around December when it’s 30 degrees and balmy.
        David HClick image for larger version
        Zero Bubble model design.
        • subicman
          • Dec 2007
          • 217
          Salvaging a Thunder Tiger Neptune, Stern Plane repairs/re-painting my OTW Molch, Repairing a D&E 1/96 Skipjack, Modding a 40mhz Robbe FC-16 to be 75mhz, finishing both of my 1/16 Kairyu suicide subs, and maybe building my OTW Type XXIII. Last but not least continuing on my 1/96 Arleigh Burke Destroyer, still torn Between USS Ramage or USS O'Kane, either way she will be named for a Medal of Honor bubblehead.
            • 342
            I've put a wtc in the 1\96 scale Skipjack and working on the Type 17B I acquired at Carmel. Found 3 leaks in my Robbe Type XXI and it runs again so might get it looking good this winter. Have some ideas for a wtc to play with as well.
            Anyone have accurate plans for the Hunley? The Micromir model seems the most accurate representation to me. Thinking about doing the modeling so it can be 3d printed.
              Bob,
              You could try contacting the museum in Charleston, SC to see if they can make plans available.
              Thanks to your support, the Hunley continues to undergo vital conservation work while also being shared with the public through exhibits and educational
              It's a fair bet that they have lofted a complete set of lines off her by now!
                • 342
                Good idea. I have sent an email off to them.
                I have been on Grabcad and other 3D model sites but haven't found anything with quality and accuracy yet.
                • robert f.
                  • Jun 2006
                  • 161
                  Well, I have been inactive for some time now so this winter will be catching up time.
                  Which means I will be starting on my Moebius Skipjack with Merriman WTC, there is a Flying Sub to finish, and last but by no means least I will have a WALRUS to get my teeth into!
                  • chips
                    • 494
                    I finally made up some replacement drive sockets for the Revel Type VIIC/41. I used a 3/32" wheel collar and some thick wall brass tubing. Now I need to install them in the sub.
                      • 342
                      I'm working on a Arkmodel Type II instead of my old projects right now.
                        • 2349
                        Excellent work on those Dumas type connectors!
                        On my bench, a ton of crud. but playing with version 2 of the capacitor torpedo, working on a piston WTC, maintenance on my running subs (inspection, greasing, and upgrades) and a beginners sub. Subs to be finished Revell type 9 and Engel Akula. To be started next Blueback and Type XXIII.
                        Still need to build....Revell Gato (converted to Trutta), 1/48 scale Type 9, and 1/144 Astute (there are others, but this is the build at the moment).
