2017 Rocky Mount, NC scale fleet run
  • chips
    • 498
    We finally made it to one of the 1/96 - 1/100 scale fleet runs in Rocky Mount, NC. There were about 20 Captains and close to 80 ship models. Most of the models were large military ships - battleships, cruisers, and carrier. There were a few subs there. I took a small USCG flotilla of three ships and a buoy barge.
ID:	137102 Click image for larger version
ID:	137103 Click image for larger version
ID:	137104 Click image for larger version
ID:	137105 Click image for larger version
ID:	137106 Click image for larger version
  • chips
    • 498
    Some more pictures.
ID:	130373 Click image for larger version
ID:	130374 Click image for larger version
ID:	130375 Click image for larger version
ID:	130376 Click image for larger version
ID:	130377 Click image for larger version
    • chips
      • 498
      It looked like there was a lot of hulls from Scale Shipyard.
ID:	130379 Click image for larger version
ID:	130380 Click image for larger version
ID:	130381 Click image for larger version
ID:	130382 Click image for larger version
ID:	130383 Click image for larger version
      • chips
        • 498
        An interesting part of this event is the "walk around", where several captains walk around the lake with their models sailing in a loose formation or convoy. One time I counted 20 ship models in the water.
ID:	130385 Click image for larger version
ID:	130386 Click image for larger version
ID:	130387 Click image for larger version
ID:	130388 Click image for larger version
ID:	130389Click image for larger version
          • 684
          Bob, thanks for the pictures! Looks like a great time. Who's sub fleet is that? Very interesting carrier / display stand!
          • chips
            • 498
            Jim,
            Most of the subs are David Merriman's, Kevin Rimrodt also broght a couple.
            There was one Dumas BLUEFISH there, built as a surface runner. The builder based the model on the SEA TIGER from OPERATION PETTICOAT. so the sub was painted a bright pink - made it easy to see.
              • 854
              Bob,
              Got any pictures on how you did Tamaroa's rudder? I'm doing a 1/48 scale USS Skylark ASR-20 based on the same ATF hull.
              Thanks,
              Bill Lambing
              • chips
                • 498
                Bill,
                I laminated the TAMAROA rudder from two pieces of 1/8" ply. There is a groove on each half for the rudder post. I don't remember what diameter rod I used for the rudder post. After the rudder halves were glued together around the rudder post, they were sanded to an airfoil shape, and covered with fiberglass and finishing resin. The rudder, rudder servo and drive motors were installed before I attached the deck. The large fantail hatch provides access to the rudder servo. The group picture is the TAMAROA (WMEC 166) in 1/48th scale, CHEROKEE (WMEC 165) in 1/96th scale, and two more 1/96th scale tugs. TAMAROA's main propulsion is a MACK Products twin motor and gearbox unit: #2500-2530.
ID:	130407 Click image for larger version
ID:	130408 Click image for larger version
ID:	130409 Click image for larger version
                  • 854
                  Thanks, Bob! Enlightening! Sadly, the Skylark did away with the large hatch during conversion. I'll have to incorporate the small, centerline hatch back in the lazarette area. This thing has been a fight-me-all-the-way project since the word "go", but I will prevail!!!
                  Thanks, again, and take care!
                  Bill
