ace nautical commander question
    • 371
    Hi all, Can anyone tell me how to add a momentary switch to control channel 6 on a NC radio? it is currenntly a 5 channel unit but there are input pins for channels 6 and 7 on the encoder? board. Would I need to put resistors on the input since there won't be pots involved. Thanks for your time. Greg
  • bharris
    • Jun 2004
    • 103
    Greg,
    Have done this to 2 of my NC's to energize a pump for pump in/out function using a 3 position momentary switch, no resistors were required for this addition, however chan 6 & 7 can be used for proportional function, so if driving a servo or a motor at a desired speed fixed or variable resistors would be required.
    The manual for the 7 chan radio (ACE8501) covers channel expansion somewhat. PM me if you need a wiring diagram.
    Hope this helps, Bob.
      • 371
      Thanks Bob ,that sounds like what I am doing. I will wire up a switch and see what happens thanks. I did find the manual posted on another site and copied it.Greg
