Help with Ohio boat
    Help with Ohio boat
    Hi all
    I recently snagged an old 32nd Parallel Ohio kit. Problem is it doesn't come with any rear appendages. Does anyone have drawings I could utilize to fabricate some? I just need a scan of the stern arrangements, photos of the drawings, anything.
    erich
    You might look through the various forums for Ohio builds.
    The builders usually show the tail group first because it's the easiest parts to build.
    Here is a photo of the rear parts disassembled to be repainted.
    Check page 11
      Hi Ralph
      The photo you tried to post did not show
        I see that.
        I posted a link to the thread and page.
        The image host will not let me embed the photo here.
        Also turns out to be the same thread but there was another thread.
        Just search Building for Ohio and scroll down several pages to the older builds.
          • 375
          see if these will help Erich I won't post any dimensions because my plan is in 1/80 scale not 1/96
            Greg, I have looked at your images.
            I can scale some numbers for these drawing with a little information.
            1. Greg boat ..What is the overall length of the hull, bow to Tail Cone? (not including propeller hub)
            2. eckloss .. what is the overall length of your hull, bow to Tail Cone? (not including the propeller hub)
            Max diameter of the hull would also help.
            These numbers will give me enough to figure the scale of the two images and them get the numbers for the correct scale.
              • 375
              I will check when I get home. I think it's 83" loa
              • pirate
                • 849
                I can cast you a set from my kit, Erich. I'll respond to your email.
                  Well, that's an offer not to pass up!
