It always seems I am a little slow when working with products such as Squadron White Putty. Is there anything I can add to the putty to keep it a little softer a little longer?
BTW, you shouldn't use spot putty for anything other than small scratches and minor blending. Heavy blending work is best dealt with using two part polyester fillers, like the Evercoat brand mentioned (UPOL is good for UK based modellers).
The reasons for this are that two part fillers dry much faster when used for filling big areas, and also are far more elastic.
I use the 3M Acryl red putty for final finishing and very fine work only.
