Anyone ever make a basic foam hot wire cutter? Can you give a brief rundown on what you need? I have used saws , sanding blocks in the past but on the larger projects wanted to try a hot wire cutter. Thanks in advance for any info on a home built cutter. Jeff Jones
faom wire cutter, how to make?
Try the Terragenesis website. Its
Try the Terragenesis website. Its a wargames terrain site but they have several articles on making hot wire cutters etc
Davie
Davie,
Great site, got so engrossed
Davie,
Great site, got so engrossed that I spent over 30 minutes there just looking around.
Wired, Rick
When I was working on
When I was working on my Hunley hull, I made one with some light ga. stainless wire and a 12 volt transformer. I used an old coping saw as a frame to hold the wire. It took a little experimenting to find the right transformer in my box of old ones from computer speakers etc.
I insulated the coping saw where the wire was fastened with electrical tape so it wouldn't short out. I cut the power output plug off the transformer, stripped the wire and twisted it onto each end of the stainless wire. I just plugged in the transfomer to turn it on. Worked like a champ!
Just goes to show that
Just goes to show that there are cross overs between the general modelling world ( using foam for hulls , etc ) and the wargames community ( making terrain , etc ) just lucky I run a wargames club lol.
Glad to be of help.
Davie
Thanks Tim for the added idea, I think I have everything here to make one after all the input and the info on the site Dave posted.
I remember your build on the Hunley, did realize you used a foam wire cutter on it. Still can't get over the rudder set up on it...
thanks agian. Jeff JonesToo old to Rock- n- Roll, too young to die ! Subs are just my speed......
