faom wire cutter, how to make?
  • jeffrey j
    • Apr 2004
    • 398
    Anyone ever make a basic foam hot wire cutter? Can you give a brief rundown on what you need? I have used saws , sanding blocks in the past but on the larger projects wanted to try a hot wire cutter. Thanks in advance for any info on a home built cutter. Jeff Jones
  • davietait
    • 135
    Try the Terragenesis website. Its
    Try the Terragenesis website. Its a wargames terrain site but they have several articles on making hot wire cutters etc
    Davie
    • jeffrey j
      • Apr 2004
      • 398
      PERFECT, thanks alot. Jeff J
      • slugejudge
        • Dec 2005
        • 43
        Davie,
        Great site, got so engrossed
        Davie,
        Great site, got so engrossed that I spent over 30 minutes there just looking around.
        Wired, Rick
          When I was working on
          When I was working on my Hunley hull, I made one with some light ga. stainless wire and a 12 volt transformer. I used an old coping saw as a frame to hold the wire. It took a little experimenting to find the right transformer in my box of old ones from computer speakers etc.
          I insulated the coping saw where the wire was fastened with electrical tape so it wouldn't short out. I cut the power output plug off the transformer, stripped the wire and twisted it onto each end of the stainless wire. I just plugged in the transfomer to turn it on. Worked like a champ!
          • davietait
            • 135
            Just goes to show that
            Just goes to show that there are cross overs between the general modelling world ( using foam for hulls , etc ) and the wargames community ( making terrain , etc ) just lucky I run a wargames club lol.
            Glad to be of help.
            Davie
            • jeffrey j
              • Apr 2004
              • 398
              Thanks Tim for the added idea, I think I have everything here to make one after all the input and the info on the site Dave posted.
              I remember your build on the Hunley, did realize you used a foam wire cutter on it. Still can't get over the rudder set up on it...
              thanks agian. Jeff Jones
              • pirate
                • 849
                Jeff,
                I found one a few
                Jeff,
                I found one a few years ago like the one Steve Neill is using on his U212 build over on SubPirates. I got it at a local art and education store. Only cost me $5-$7 and it runs on 2D batteries. Works great.
                Pete
