Epoxy - Works well!
    Epoxy - Works well!
    I have been using a new epoxy (for me) and wanted to pass it along. It is made by the makers of Goop. It is called Plumber’s Weld Epoxy Paste. It is a two-part epoxy that is easy to work with, sets in 20 min, and is waterproof. It will even set up under water. It works great for attaching bulkheads because it stays where you put it. Great for fillets! I even used it to attach my bayonet ring in my Sushi sub. I purchased it at my local home improvement store. BD.
    Edited By Bigdave on 1149718029
  • silent runner
    • Jun 2005
    • 188
    How well does it come
    How well does it come apart when you drop your hull and bend the bayonet ring?
    :O
      Thanks for the tip Dave.
      Thanks for the tip Dave. I'll pick some up.
        Hopefully Mike, I hope I
        Hopefully Mike, I hope I never have to find out!
        • tabledancer
          • Feb 2005
          • 573
          Very good Dave,Have to go
          Very good Dave,Have to go over to Lowes sometime this week I`ll check it out .
          TD
          • hm3
            • Sep 2005
            • 8
            Great tip. Thanks dave. I've
            Great tip. Thanks dave. I've been mulling over what to utilize on my boat.
            • k225
              • Nov 2004
              • 108
              Another product from them i
              Another product from them i have been using with success is Goop Marine Fix fast 2 Epoxy Paste
              • danl
                • Oct 2006
                • 39
                Anybody use JB weld?
                Other than a long cure time, how is JB Weld as a adhesive and filler?
                • crazy ivan
                  • 659
                  JB Weld? Excellent!
                  JB Weld? Excellent!
                  sigpic
                  -George Protchenko
                  • kazzer
                    Banned
                    • Oct 2006
                    • 324
                    Epoxy Putty
                    I use these putties a lot, I really like the wood because it is lightweight.
                    The Faststeel is extremely hard and you could use it as a bearing surface.
