Dissolving epoxy resin
  • Filter
    Is there any effective way to dissolve/remove/eliminate cured epoxy resin?
    Erich,
    There are a number of (nasty) chemicals that can be used, such as methyl-ethyl-ketone or sulfuric acid, but I'd start here:
    p.s. what are you trying to remove the epoxy from?
      Jeff
      While cleaning up the storage room, I came across a sub I bought many years ago that has lead shot mixed with resin as ballast in the bottom. I'd like to remove it.
        Erich,
        If the inner hull where the epoxy/shot mix is located was not prepped, then you might be able to knock it out.
          I've tried pounding on the stuff with a large hammer and a chisel to no avail. I've also tried direct heat via a butane torch, which gives me some progress. But it's extremely slow going.
