Material for control surfaces... - what to choose.
  • robse
    • 183
    [color=#000000]Hi, fellow subbers.
    In the process of scratch building my 1]
  • kd6hq
    • 102
    How about wood, it cheap,
    How about wood, it cheap, needs no special mold, easy to replace if you don't shape it correctly and easy to waterproof.
    -- just a thought --
    • thierryc
      • 162
      I used lexan for a
      I used lexan for a 1/100 LA, it worked perfectly. Easy to work with, non-brittle and gluable
        How about sheet Lexan polycarbonate,
        How about sheet Lexan polycarbonate, which comes in different thicknesses. Much less brittle than plexiglas, sands and shapes/machines easily, and takes paint well. I made some bow planes and skegs that worked out well.
          Our minds work in the
          Our minds work in the same way.
          • robse
            • 183
            Hi again.
            Thanks alot, guys! I
            Hi again.
            Thanks alot, guys! I now have a few ideas to take into early tests.
            And Art: I didn't know my mind WAS working..
            • uss silversides
              • 197
              I like to save a
              I like to save a buck where I can, so I have used plexiglass for all of my control surfaces. The kind of plexiglass I am using (if there are different kinds) is not brittle at all, and even though I have not tried them out yet, they seem to be very durable.
              Just my two cents worth
              Jon
                Jon,
                I guess I'm not the
                Jon,
                I guess I'm not the best driver, but I have run my subs in some tight places around docks and in test tanks that have interior metal beams to support the glass walls, and have broken quite a few "original equpment" control surfaces.
                Plexiglass is a brand name for acrylic. I have broken and repaired many acrylic products including an acrylic WTC, which fractured when I tried to insert an end cap.
                I still recommend polycarbonate, like Lexan, for these uses, in spite of the additional cost.
                Art
                • uss silversides
                  • 197
                  Yeah, you're probably right.
                  One
                  One problem I have with the translucent and transparent materials is even when painted they let an unscale-like bit of light through. What do you do about that? Just live with it?
                  Jon
