GRAUPNER MC-15 / 40MHz / channel 91
  • profesorul
    • Apr 2014
    • 106
    HI there ,
    Next week I wheel have in my hand (hopefully) a Graupner MC-15 / 40MHz / 91 channel .
    Regarding these I spent all my day (7 to 8 hours !!!) , today in order to find some informations / videos / tutorials at least a PDF Manual for it .
    But despite all of my efforts I couldn't find anything , but NOTHING , zip , Zero informations about it . Mybe I'm not so skiled with internet .
    I thought maybe was made only 400-500 pieces and nobody cares to put on internet some info .
    I know was made around year 2008 ( not OLD , huh ) , and I thought is my last chance to open a thread here about these RC station .
    Any information is valuable , so Please feel free to share with me what ever You have .
    I am "brand new" to these field and I DON'T know anything about RC . Was the only one I get afford to buy . Is gonna be used for an RC submarine project .
    So if You have some directions for me don't hesitate to tell me .
    All the best
    MARIUS
    Re: GRAUPNER MC-15 / 40MHz / channel 91
    In Dutch I think.
    https://www.gebruikershandleiding.com/G ... 8.html#af1
    • profesorul
      • Apr 2014
      • 106
      Yes is a very "common" language ....
      Thank You .
      MARIUS
      • profesorul
        • Apr 2014
        • 106
        HI there ,
        The time for Preparing my old RC GRAUPNER MC-15 / 40MHz station is coming Little by Little .
        But here I need some Experts Advices abut how to Expand the Nr of channels from 6 to 10-12 channels .
        I know is possible because I opened the case and I see these ][/url]
        [b]And these is the way I want to look like ]
        Please don't tell me to go to Graupner site . That site is USELESS !!! , believe me . I spend almost 2 nights in order to find a way to correspond with someone but with NO success .
        As a matter fact I don't need them . Al I need is what type of components are suitable for and If is necessary to make some settings on it .
        Can some one help with that ?
        Many Thanks in Advance .
        Yours MARIUS
        • ober freak
          • Jan 2014
          • 114
          Hi Marius
          The MC-15 can support up to 6 1- or 2-way switches (on-off or on-on) onto the brownish 2-pin connectors and up to 3 3-way switches or potentiometer/sliders onto the black 5-pin connectors at the same time (page 6 in the linked instruction).
          For the 1- or 2-way switches (most of them are 2-way) use pin 1 and 2 (one outer and the middle one) for the 2-pin connector. Possibly only useful to activate mixing programs on the MC-15, on my MC-19 i can also use them channels.
          For the 3-way switches oder potentiometer use pin 1 and 3 (the outer ones) to pin 1 and 5 (the outer ones) at the 5-pin connector and pin 2 (middle one) on pin 2 or 4 on the 5-pin connector, turning the connector means reversing the channel.
          Graupner uses 4.7 kOhm potentiometer linear type; the sliders are 30 mm types.
          All connectors are 2.54mm / 100 mil / .1" types (distance between pins).
          I upgraded my MC-19 with 4 3-way switches:
          I used these switches http://www.reichelt.de/Female-Connector ... +094-1-005
          Marco
          • profesorul
            • Apr 2014
            • 106
            THANK YOU MARCO
            Absolutely Awesome ,
            MARCO you are my savior ,
            Tell me Please]MARIUS[/b]
            • profesorul
              • Apr 2014
              • 106
              "EDIT",
              Your information about the components had a great value and anticipated my next questions ,
              If you allow me I will post them on a modeller website in Romania ,
              Do you have manual for MC-19 in English ? .
              If so do you think it can be somehow send to me on email address?
              THANK YOU AGAIN ,
              MARIUS
                I have an MC19s. You can use a fairly wide range of pots with the set, I find pots from 5k-10k work just fine with the set.
                  Manual in English for MC19.
                  http://www.graupner.de/fileadmin/downlo ... 821.GB.pdf
                  • profesorul
                    • Apr 2014
                    • 106
                    THANK YOU @sub culture ,
                    Is a very useful information .
                    Thanks for The Manual .
                    MARIUS
                    • ober freak
                      • Jan 2014
                      • 114
                      THANK YOU MARCO
                      As far as I remember the MC-15 has fixed assigned channels, so just plug them in and you can use the corresponding channel on the rx.
                      The MC-19 can freely assign each input to any of up to 12 channels. (in ship and car mode)
                      MARIUS
                      sure!
                      Marco
                      • profesorul
                        • Apr 2014
                        • 106
                        THANK YOU MARCO ,
                        Soon as I get the time I wheel go to buy a couple of thees 2-3 switches with 3 way position .
                        If I could find wit a long or flat arm wheel be nice .
                        MARIUS
                          Some times when looking for switches, I find the rating I want but not the lever I want.
                          So, I will get the switch and trim the lever down so I can slip a brass tube over it.
                          I can then make the lever any length I need and I can flatten it to drill hole in it for control rod.
                          • profesorul
                            • Apr 2014
                            • 106
                            Yes You are right and it's a good idea .
                            Those picture I post it only as a reference , not to buy exactly .
                            MARIUS
                            • profesorul
                              • Apr 2014
                              • 106
                              [b]BIG , BIG , Problem ] .
                              What can I do ? . Please Advice , Is the Only Rx with 8 channels I have .
                              See pictures :
                              MARIUS
