SLA batteries and ESC
  • Filter
  • starfighter
    • Oct 2014
    • 3
    Is it OK to use a 12v SLA battery with an ESC? Many of the ESC s available do not say they're suitable for SLAs, only NiMh, NiCad, LiPo.
  • ober freak
    • Jan 2014
    • 114
    Re: SLA batteries and ESC
    Hi,
    You can use them without any doubt,
    may be the low voltage safety mechanism of those newer ESC's doesn't react correctly as SLA's where quite outdated in most vendors opinions.
    LiFePo4 is the direct replacement for SLA types, 4S LiFePo4 replaces 6S SLA (12V). If the ESC supports LiFePo4 mode you can use it without any disadvantages.
    Marco
    • starfighter
      • Oct 2014
      • 3
      Many thanks for the info and the quick response.
      • Wheelerdealer
        • Jun 2006
        • 315
        Volts are volts, no matter what the chemistry of the battery is. The esc will only be able to spence the voltage of the battery, not what type of battery is connected. Some ESC have low voltage cut offs to protect Lipos etc but they work with any battery as long as the voltage is with the operating range.
        • starfighter
          • Oct 2014
          • 3
          I suspected as much, but I thought I would check as I wouldn't want to damage the ESC. Thanks.
