Will a standard 72mhz TX/RX work in a RC Sub.
  • oldnoob
    • Jun 2011
    • 33
    Will a standard 72mhz TX/RX work in a RC Sub. or do i need an old 35mhz or 27mhz or 75mhz system?
    Tested my Old 72mhz system on a road,at 1/2 of a mile, functionality confirmed via cell phone communications, and it worked fine. Why wouldn't it work in water?
  • roedj
    • Apr 2008
    • 162
    Re: Will a standard 72mhz TX/RX work in a RC Sub.
    It would work just fine assuming the electronics were OK which they seem to be as you've already checked them out.
    The problem is that the use of 72MHz for surface (or sub-surface) R/C is not legal in the USA or Canada. It may be possible to have a competent licensed technician convert it to 75MHz.
    Dan
    • giovanni
      • Mar 2012
      • 207
      You can easily convert your 72MHz radio to 75MHz if you want to use it for subs.
        A lot of us r/c sub folks use Radio South:
        • giovanni
          • Mar 2012
          • 207
          Tony converted my Graupner MC-19 radio and has great service.
